hotpoint WD420 washer dryer
21 Oct 2007
Kent
Hi all,
my hotpoint thingy has developed a weird fault, on starting it takes a little water in and then stops, sometimes the drum will turn 1/4 turn then stop, then go the other way after a couple of minutes, it has the door locked and wash light on, then it just seems to freeze,
any ideas please?
peter
it should fill twice in about 3 mins if it only fills once you poss have a open circuit valve .
thank you, yes it only takes one lot of water in and then freezes.
i will check the valves.
is it normal for the drum to do 1/2 turn then stop, as sometimes it does this for a few mins before seeming to run normally?
Hi Rocks, thanks for your help, Mr Hotpoint came out yesterday and said the main PCB was faulty so now wait 5 days for another one.
Will keep you posted
Peter
