Have a WD440 which keeps tripping the thermostat during the drying program. Been trying a few things tonight and the following seems to be happening;
It seems to dry ok on the lower heat setting.
It seems to dry ok if I start on the lower heat setting then a few minutes in select the 'Drying heat high' option (not sure if this actually changes anything once the program has started though.
But if I select the 'Drying heat high' setting about 2-5mins in the thermostat trips. I then get a fast flashing on/off light. Plush a flashing 'Drying heat high', 'Reduce Crease' & 'Time Save' light (lights 1, 2 & 4 in the vertical stack of 5 lights). Fan motor (at rear of heater manifold) appears to be running ok (put finger on the spindle and can feel it spinning).
Any ideas .... has the thermostat become a bit too sensitive due to be reset quite a few times now ?
Thanks in advance for any advice you may be able to offer.
