My washer dryer will not empty during a wash cycle.
The pump runs for around a second and then stops eventually leading to a lot of flashing lights.
I have checked the filter and removed an elastic band from the impellor and also cleared some coins from the trap in the hose but did not find any real obstructions.
The output hose seems clear and runs freely when lowered below the drum to syphon off the water.
I removed the pump and have bench tested it and it runs fine even under load.
So basically my machine tries to pump out and water flows out of the outlet but then stops after around a second.
Has anyone else experienced this?
