Hotpoint WF541 Fills & empties &lights flash at end
Jaq
22 Nov 2011
Cambridgeshire
Had this problem before but seemed to right itself..we did spray between the buttons on the outside with WD40 but can't say that had anything to do with it as it didn't sort itself out straight away....
PROBLEM: At end of cycle after spins instead of finishing it starts to fill through the conditioner side but it is emptying at the same time, probably not as quickly..this lasts for 5mins..at the same time the on/off light is flashing & so are the 'rinse hold' & 'mini hold' lights flashing (3rd & 4th lights down) ..the machine can't be turned off..it won't do anything...haven't tried the wall socket difficult to get to...After 5 mins you can turn it off & open the door but the washing is quite wet & there is still water in the bottom of the drum...it will pump out with no problem if I set it to afterwards but again the washing is still quite wet because it only empties & if I set it to spin & pump afterwards it starts with the lights & filling again...have washed several loads today but have the problem of very wet washing....have checked the little door at the front & taken out several coins ...will try kicking it next am losing the plot with it ...think I'm living in a laundry wet washing everywhere...can't seem to find exactly the same amongst others problems so grateful for any help :?
Thanks for coming back....sorry but a mere woman ...can you tell me in laymans terms..what's the pcb...& is emw the co to buy from...I know I'm dopey but I gotta pass this on & if I don't know what I'm talking about..well....& guess it's more than obvious that I don't... Jaq
Pcb is the computing part found at the back right hand corner , with a plastic case round it. Emw is in Nottingham they sell recon Pcbs for 45.00. Or call hotpoint all in charge parts and labour 105.00
  • Thanks
Reactions: Jaq
Much appreciated ~ found company & will pass the rest on & will then decide whether or not it's worth fixing or replacing, many thanks Jaq
