HOTPOINT WF541P
20 Feb 2010
Kent
does anyone know why RINSE HOLD and MINI LOAD flashes very quickly after you turn washing machine on. the only way to stop them is turn the appliance of from the plug. water is filling up, not going into drum just emptying straight out. checked filter, collected about six pounds from it.???
Wot number lights are they from the left 1 and 3 2 and 4 etc
you have a ntc problem ,check the 2 thin blue wires on the heater found at the back, also check connections are tight on pcb ,if that fails a new pcb is req .
Printed curcuit board found at the back in the corner covered in a White plastic cover.remove rear White cover .
