Hi
I am hoping someone can help me with a frustrating problem. My WMA50N stopped working mid wash and the door locked light was flashing.
Changed the door lock, still no joy so checked the control module, found a blown track so repaired this. Lights working correctly now but the drum would not turn. Checked the brushes looked a bit dodgy so changed these (for good measure also cleaned out the 'filter chamber'.
The machine now fills with water and the drum turns once then stops. Machine pauses for a couple of minutes then the drum turns once more and stops, it does this about four times and then the end light comes on. It does this on all cycles including spin only. It seems to be filling and draining correctly. I have reset the control module and checked it is configures correctly - made no difference.
No idea what to try next - any ideas would be greatly appreciated.
