How Best to Remove Adhesive Residue from Wooden Panel - Pics
17 Dec 2006
Hi Guys
I have a wooden ceiling panel that has some adhesive residue on it that needs removing. I have tried using a razor scraper to get it off, but that has scraped the wood a little.
What's the best technique to get it off? I'm thinking sanding. In which case:
- What type of sanding paper is it best to use?
- I guess I'll then have to restain the sanded area. How difficult will it be to find the matching woodstain and how do I go about finding it?
Finally, the wooden panel is a tongue and groove panel used for covering ceilings. How difficult do you think it would be to buy a new one if I needed to?
Many thanks
Easily replaced, looks like wood glue so need a sharp wood chisel, acetone won't touch it.
I've already tried a sharp scraper on it, and this is the residue.
What are the forum's thoughts on sanding the remainder off? Would this be a bad idea as it would then be difficult to restore the finish??
