I was thinking of other inputs such as "call for heat"
Mine also has a primary flow switch, gas pressure sensor, temperature sensors on incoming and outgoing water; fan pressure switch, boiler temperature setting, cylinder stat, room stat weather sensor etc
And it has outputs to start fan, start pump (and overrun it); open gas valve; start ignition and time if it works; change condition of 3-port valve
a PCB is not an item I change often (as a heating engineer carrying out boiler repairs and servicing). Just because there is no output, does not mean the PCB is duff. It has to act on number of inputs to give an output.
Proper way to establish if PCB is faulty is to get to know what it is designed to do and then check the conditions that might be causing it to hang up. only then change it if it indeed is faulty.
I would definately say that if a PCB was a black and charred mess, then it is pretty kippered... But since I have never seen one in such a state, I would have to test the boiler in a logical sequence
