How do I conduit/ lag plastic pipes buried in concrete?
4 Feb 2010
Surrey
Hi- I'm burying 15mm barrier mains water pipe, and CH barrier in a kitchen concrete slab before Jabfloor insulating it. (Basically I think it will be easier than chanelling out the underside of the Jabfloor for the pipes).
Is something like JG 15mm conduit OK for this? Or is 22mm easier/ better?
And can I/should I use foam pipe insulation in the concrete for the CH pipes instead of conduit?
Any help gratefully received. Thanks!
Run the plastic pipe within a flexible plastic liner.
Hep make it.
Search on their website for info.
-And do the CH pipes need insulation? How do I do this if conduit already on pipe? Thanks.
