Hi. My home was built in 1958. In the 1970's the walls of the lobby were painted. I've removed all paints from the walls. There were 3 coats, the last coat would have been put on about mid 1970's. The final coat was glossy and bubbled up when paint remover was applied. The very first coat did not bubble up, but was softened by the paint remover and I scoured the wall with a scourer and warm water and washing-up liquid.
So, the walls are essentially free of paint, there is just a faint colour remaining.
I've actually got two types of wall situation here, #1 and #2.
Wall #1. The surface of the plaster (white) is really quite smooth.
Wall #2: Here, the skim plaster surface was actually removed and will need to re-plastered.
Okay, regarding wall #1: Do I sand down this wall? I think I do. Also, do I need to paint the wall with a primer, perhaps I do, since the plaster is not new? Again, I think the answer is yes. Although I don't know what to buy.
Regarding wall #2: The substrate that the new plaster will adhere to is of two types. Part of the wall, the substrate, is really soft, it's easy to rub it down with the fingers. Another part is very hard, I'd say that is called browning. Not sure if the other soft substrate is called browning, it's a very light colour.
Now, after the wall is skimmed with plaster, will that wall also need to be sanded? And, will it have to be primed? I suppose so, even though the plaster will be new, with I suppose, the same primer used on wall #1.
Your guidance appreciated. Thanks.
EDIT: Aaah, I think, unless anyone says differently, I need to use something like Zinsser GARDZ for wall preparation.
