How effective are advertised lawnseed cures?
14 Jan 2005
Glamorgan
I have a lawn with a corner area (approx 4m sq) suffering due to it being in relative shade under a mature eucalyptus tree.
I regularly read about "advanced lawn seed mixtures....only available direct from UK distributors" being advertised in sunday newspapers. Which are said to grow "anywhere, even bare shady areas".
Does it deliver?
Normally I would not believe everything written in newspapers, particularly full page adverts offering miracle cures. But has anyone tried these with any success?
VMT - Doug
Doug: Sutton Seeds are a reputable company who provide grass seeds for a whole host of differing environments. You need a grass suitable for shady area's.
Have a look at this
Thanks Lou - The website was an interesting read, but did not go into details about its use. Do you know what ground work is required before use? I've given the lawn its first cut of the season (on high setting) and looking to give it a feed. But don't want to do too much before establishing the new seed.
I suppose a 'sprinkle seed and forget' is too much to ask?
Doug
I don't think i would waste money on seeding and feeding stuff. Because it's such a small area i would returf it. But don't buy turf from a diy store cause it's rubbish, you can get good turf for £3 per meter so it won't cost you much if you pick it up in the car and will look nice for longer obviously eventually you will still have the same problem, grass needs sunshine.
good luck
The trouble with turf is yiou do not get the same selection of grasses.
Get rake the area, a grass rake is ideal, and rake the area well to remove and debris and also break up the surface of the soil. Add some new soil if need be as the seed needs loose soil to enable it to germinate. Sprinkle your seed on top, about a handful per sqaure metre and rake. Keep moist and wait for the growth. Late March / early April is a good time to do this
40gsm of seed is the "normal" rate but as near as dammit will do
mixing it with some sand tends to keep birds away
