Have just removed old parquet flooring (too damaged to repair) from Victorian house. It was stuck down with bitumen onto concrete. I want to lay solid oak flooring (18mm) in its place. My question is how level does the concrete need to be, in one area there is a slight hump and hairline crack. I have laid a straight board over the area and it does not lie flat. I intend to use combi dpm 3mm under the floor will this help to level? Don't really want to level whole floor and increase the height as want the new flooring to go under the skirting into the gap left from parquet. Skirting is original so cannot easily replace if breaks when removing and it does not take kindly to removing!
