This is a bit open ended because it depends on the strength of mix you intend to use. Generally for this kind of job a mix of about 4 sand to 1 cement should be ok so I would get yourself 3 bags of cement and 12 bags of sand for starters and you will soon be able to work out how much more you may need as you use it.Good luck.
