How To Cover Up Hole Left by Tumble dryer hole?
7 Jan 2024
We are about to swap our old tumble dryer for a condenser type and this will leave a hole (approx 13cm diameter) in some wall tiles where the outlet pipe currently goes. .
This is in the utility room and, so, doesn't need to be super-neat, but, I need to find a way to cover the hole.
Anyone got any suggestions?
A closeable wall vent perhaps?
Sorry, should have explained better.....
The vent pipe goes into a cavity between the utility room and an extension we had added to house, then runs along to an outside wall. I plan to remove the bit of pipe sticking out in utility room and leave the rest in place.
This will leave the hole in wall of utility room and this is what I want to cover up. Some sort of thin blanking plate would be ideal but don't know where to find one!
Would a cut to size, edge polished, drilled and countersunk plastic disc do you?
Then try Simply Plastics or any other plastics supplier such as Amari Plastics, etc
Better to fill the masonry properly, as recommended, but as a short term fix a plastic or plywood disc both sides would at least look neat
Vent suggested would not look out of place.
Any in laws you dont like? They make great hole fillers!
That's exactly what I was hoping to use, but, didn't know where to get from!
Many thanks for the information.
I will fill in the hole with expanding foam and then cover with one of these disks - perfect :giggle:
