Bathroom renovation means I'm moving the pipework of an existing radiator to accommodate a towel radiator. I know you'd normally just drain down the CH system, do the work and then refill. However, once I've moved the pipes and fitted the new valves, tested the connections with a re-fill and reinstated the plasterboard wall over it all, I'll need to do a whole load of tiling over that area before finally hanging the towel rad.
So here's the question: I've got a Worcester Bosch combi, which I know has an integral bypass in it, and I don't want to have to rush at the tiling just because there's no hot water in the taps, so what do I do to drain down the CH but maintain the DHW?
Thanks in advance for your help folks.
