how to fit a shower screen
15 Apr 2010
Angus
i have a shower a glass shower screen which has plastic fixing brackets, that need to be fixed to a tiled wall that has little support behind it. how would i go about this.
Use a tile bit, the size recommend for your rawl plugs.
They are a little more expensive than the normal masonry bits.
You'll need to mark out your holes on the tiles, this is best done by sticking some tape to the area where holes will be drilled. This will also prevent the bit slipping on the tiles and marking them, when you drill.
What do your mean little support?
