how to lay floor slab around this drain???
10 Nov 2010
Norfolk
i was just wondering what you guy's would recommend i do about concreting around my kitchen waste pipe that comes up in the corner of the new floor.
View media item 31904do i just dpm and insulate up to the walls as per normal and simply box it off before conrete? or are you allowed to concrete round the pipe?
if i box it off do i use expanding foam to fill the gap between the box and pipe?
any help appreciated,
Concrete the thing in if your happy your never going to need to get to it but i personally would have fitted a slightly bigger pipe around it just below ffl incase it ever needed removing. Make sure you dont smash it with the poker when you pour that conny.
Similarly, I would bring the 4" drainage to top of concrete, then connect into that with an adapter. Then the drainage is flexible for adding new connections or even a toilet in the future !
If whole thing is under the floor level, I'd even be tempted to take the 4" into the room where the drainage begins (kitchen ?).
Agreed, buy a reducer cap that has an inlet for either a 38mm or 32mm waste pipe.
thanks guys,
the camera angle doesn't really show it but the 4" reducer will be slightly above floor level so can be altered if needs be.
