We are due to have the carpets replaced in our living room in a week or so. I'm taking the opportunity to sort out a small area by the fireplace which had always had a noticeable dip in the carpet. Turns out on lifting the existing carpet that the original fitters had ignored the difference in height between some old tiles and the floorboards, and just chucked a few more layers of cheap underlay in to fill the void.
I used a piece of scrap 6mm MDF to see if this might fill the gap - at the point where it is closest to the floorboards. However, by the time it is flush with the hearth, there is approximately another 6-9mm gap with the surrounding floor height.
I'm not sure whether that makes any sense whatsoever, so I am hoping some pictures may help:
I'd like to sort this out, but to be honest, am not sure of the best, or most practical way of going about this:
A few points to note:
1) The floorboards that surround the tiles are not completely level, but sufficiently so that I don't intend to do anything about it
2) I'm not convinced that the tiles that are currently in situ are completely sound
As such, I'm not sure whether any or all of the following are viable options:
1) Concrete over the tiles, smoothing over to finish flush with the existing floorboards. Drawback: this might crack once the gripper rods for the new carpet are hammered into the concrete?
2) Self-levelling compound over the tiles. Drawbacks: the existing floorboards aren't quite level, so this may not end up sitting entirely flush. Given that the tiles are also not entirely sound, might the SLC break up over time?
3) Use thin layers of ply or mdf to build up successively?
Many thanks for your help all!
