Hi there, a rad on an open vented circuit has started to make a quite loud humming noise when the boiler( worcester heatslave) is powering the c/h. The system works ok with rads getting plenty hot and no air in them.Is it likely to be sludge, faulty rad valves (no trv's) , or something else you can think of ? Cheers in advance, STIX. Forgot to mention the valve incorporates both flow and return and says Yorkshire something or other on it.Hope that helps.
