HW and CH needs Reset
9 Oct 2004
Renfrewshire
Hello
For the last week or so, I have an recurring error with our vokera linea 24.
Its a 01 error - that indicates an ignition problem and this means no CH. I can reset the boiler and get HW only (quite the thing) for as long as I need. But if I choose to have both parts in action with or without a timer setting there is an inclination for the error 01 to reappear.
So far I have had 3 full days operation on the bounce as programmed but tonight again it took the huff and I had to reset. It failed 1st time and 2nd time but was OK reverting to HW only. After about 10 mins or so I switched to CH but it failed and I had to leave it again for about 30 mins before trying again. As I type this its fully back in action but Im clearly not confident it is stable.
My question is does 1 component contribute to this circumstance or is it a likely combination of age and wear within the combustion chamber?
Thanks for reading and any replies
01 is an ignition lockout
Fault i suspect would require an RGI to repair. The CH runs at a lower burner pressure and i would be checking these first
