HW won't heat
7 Oct 2008
Cardiff
Hi guys
Changed a cylinder the other day refilled heating works fine, hot water won't heat. No 2 or 3 prt valves. Has air lock I think just can't get it out any tips would be welcome
Are you a DIYer,or plumber???
this type of problem is usualy caused by only partial drain down. on a vented system,
Is it vented or sealed??? you dont say!!!
If its vented then drain down to the lowest point,
eventualy it will pull the air out when it runs clear stop draining and it will refill no promblem.
