Hi
A hydro shower has been fitted in a friends flat, the hot water cylinder is at floor level, when the shower is used below the level of the cylinder the water temperature is fine, when the shower head is used standing up then the water temperature reduces to luke warm.
Would i be right in assuming that the change in temperature is due to the shower head being above the cylinder height, as I was under the impression that their would be enough suction created through the venturi nozzle for this not to matter?
Thanks for any help
Also if this is the case would it be possible to fit a pump to the hot water side in oredr to improve this?
Thanks for any help
