- Joined
- 27 Jan 2008
- Messages
- 27,406
- Reaction score
- 3,309
- Location
- Llanfair Caereinion, Nr Welshpool
- Country
I would like a device that realises when it's going to be a nice day, and turns off the boiler, and one which once the boiler has modulated to full extent and has started to cycle, it again turns boiler off until the weather has deteriorated.
At the moment it is manual, as the weather improves I turn it off for summer, and when it deteriorates I switch it on again. And likely that is the best method!
I have looked at the idea of automation, however with clear skies in summer nights are cold and days are hot, and the idea is to keep house as cold as possible so it does not get too hot as the day progresses.
I did consider the idea of two thermostats and a latching relay, so at a temperature the central heating is never programmed to reach say 22°C it will latch off, and when it had dropped to a temperature below what with would normally allow at night say 16°C it would release.
My home does not heat up quick, nor does it cool down quick, so the other idea is if temperature at say 2 pm outside exceeds a set limit switch off for 24 hours.
I looked at IFTTT and actually tried it, however one day internet failed and as a result heating failed, it's OK getting out the phone and seeing the temperature at home and changing it, but relying on weather reports which can fail.
I have a couple of spare PLC's and a HMI so not a problem making the device, however seems I am reinventing the wheel, I am sure some system already exists, so what is on the market?
