Hi I have a Ideal C24 which I’m having a little problem. The CH system stops now and then, the boiler sounds fine, someone said I should change the PCB main board, but been there £160 I need to be sure, I replaced the CH Thermister on someone’s idea, which help and stopped the problem for about 2 days.
this might help could it be the hot water side (tap). When I turn the hot water tap on the water seems to be a week slow then after 3 sec it starts kicking in.
Hope you can help...
