Hi there,
I have enough BTU left in the scope of my boiler and want to add a rad into the same room as the boiler is located in. What I need to know this, is there a min distance from the boiler 22mm pipes flow and return from which you can take the first radiator feed from? Including the feed to the new rad the entire length is about 2 meters including flow and return. I hope I've explained that well.
Les.
Les.
