ideal classic lxff flue boiler problem
19 Apr 2008
Cheshire
hi the boiler isnt heating up any radiators
.the water is not too bad just warm. the boiler fires up then after a minute shuts down itself ,but the radiators are not even slightly warm as if no water is heating them.
the heating is on a danfoss thermostat controller which has a mind of its own and switches on/off varying times.sometimes everything works fine ist does this every couple of weeks then works ok again.
please help
Could be a sticky pump - or some other intermittent fault. Could be hard to find until it gets to be a "reliable" fault.
yes i had someone check it over he said he couldnt find fault as all cylinders where working and the boiler was having a good day ie turning on and off as required.
tbh the radiators where at least turning on even only for a few miniutes getting a little warm ,now there freezing :cry:
HI
1.faulty pump
2.blocked heat exchangers
3.faulty ch/hw sensors
need more details
