Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Looking for a smarter way to manage your heating this winter? We’ve been testing the new Aqara Radiator Thermostat W600 to see how quiet, accurate and easy it is to use around the home. Click here read our review.
Pilot lights stays lit, then main burner comes on for varying amounts of time then when main burner shuts down i believe the pilot goes out with it. any ideas?
No i havnt been there when its happened it my mothers house, will be going tomorrow after work, strange part was i fitted a gas hob the day the fault occured, but only shut gas off then re-lit boiler. going to test for 240v across L & N on gas valve. Cant find documentation on boiler. works fine for several hours then as burner shuts off the pilot goes out as i believe.
