Ideal Evo He fault code sos
21 Mar 2010
Kent
Can anybody help? My boiler is showing a code H3 please help
Thanks for your help, someone else has mentioned this Thermistor, Could you tell me where is it, will it need replacing? or is it fixable? any advice how to do it would be very appreciated!!
Theres a check or two you can do if you have a multimeter and a little electrical knowledge....??
It's on the underside of the boiler with two (possibly blue) wires going to it.
There may have been a leak onto it causing the problem.
Yes it is the DHW thermistor/ntc.
Easy to change, but is in a wet pocket, so cold inlet need to be turned off first.
