ideal isar 30he (i have dhw but no heating)
31 Mar 2007
Durham
hello,
i have a problem with this isar, it all works on dhw but heating side pump runs,but fan will not kick in
on the display figure 5 shows.
the fault diagram dose not show me the way to solve the fault,
i would be greatfull if someone could give me some direction on the problem. :oops:
Have you switched off power at the wall for 30 secs?
5 is just the pcb telling you it is an Isar HE30.
hello,
dave i have turned it off at the fuse spur for about 20sic turned it back on pressed the reset. just done the same dhw no heating. any other ideas,
scratching my head at the minute.
thank for your time.
At a complete long shot, check that the jumpers on the pcb are pushed in fully and a tight fit.
You could also check there is 240VAC on the switched live to the boiler, but as you are getting a 5 up, I would suspect the old faithfull Ideal pcb.
Usually the only time the 5 on its own is displayed, is when the boiler is first switched on at the mains.
thanks dave,
i'll give it a good look at and i'll let you know the outcome.
thanks again, regards tony
hello dave,
i have had a bit of a bad day, i phoned ideal about this combi and the girl that i spoke to says it was the thomisters,i changed them and h-9 fault come up so i went back, so i went back to the part center and got a over heat thomister, the boiler went through one cycle and display had c on but the burner was flashing as if it was up to temp,after hour making sure that the pump was working and no air in the system give up.
i phoned ideal back and spoke to a lad who went though very thing with me, so off to the part center again for a diverter valve head, i yet to fit it but hopefully it will work.
have not made much off this job but thanks for your advice and i was grateful for your advice,
regards tony :wink:
Unfortunately the 'girls' that Ideal employ in their call centers are absolute rubbish :x
Been many a post here about them.
If you ever phone them again you are best to ask for Dave Kemp. He is the only one most of us trust :wink:
(Sorry techy :lol: )
I think this will end up another Isar pcb fault :roll: :x
Whether you end up out of pocket or not, it will be a valuable learning experience, if nothing more than NEVER give a price to fix an Ideal Isar/Icos. :x :cry:
This is why I tend to tell the customers to call Ideal in :wink:
Hes a legend
Sorry to hear that techy, Please accept my condolences.
The last thing you should be thinking about now is posting on here.
Puts things into perspective I think, which we all sadly need once in a while.
