Ideal response 80 automatic air vent
15 Oct 2008
Surrey
Hi
my trusty .. combi boiler has a couple of issues
The automatic air vent on top of the heat exchanger is leaking water occasionally
If they leak water do they also risk sucking air into the boiler .Is this an easy thing to replace on this model of heater .any suggestions for replacements repair ?
I have also got a slight leak from the CH flow pipe it is where the pipe connects to the boiler. I have tried tightening the nut to no effect . is it me to drain the system and reseat the joint or put some anti leak fluid in
