Idesit D41 Dishwasher Problem
14 Dec 2009
London
HI
i have a d41 indesit dishwasher which is not working properly. It starts a programme but then stops with the first two pgm lights on (from the left) cannot work out what problem is - can anyone help?
Gary
First two led's flashing means: Timeout empty from Pressure switch during draining. The culprit could be any of the following:
• Drain pump interrupted/faulty.
• Drain hose obstructed/plugged.
• Pressure switch stuck on full.
• Electronic timer.
• Water in small pressure switch tube.
• Air bubble in drain hose.
Look at the easy things first (pump & hoses) & progress from there.
Good luck :D
