Ikea - Whirlpool DWH B00 four flashes
30 Oct 2013
Hi all, it's a common problem (I've seen a lot of similar topics not only in this forum). So I've already changed draining pump, cleaned the pressure switch, but still I have the problem:
when I start using a program (I've tried all), after a while the DWH stops,
starts beeping and I see the 4 flashing light. The dishwasher is full of hot water; after "resetting" the error (pressing the start button for about 2 seconds) and waiting a while, if I choose the Pre-Rinse program and start
the dishwasher, all water is drained out.
I've checked the draining pump (and I've changed it) and it is clean; filters are clean, pressure switch is (now) clean. I've run the test program and it
runs til the end (I hear 3 "beeps" , the machine stops without water inside and there's no error indication, I think it's a correct end of test program)
Any ideas ?
Can it be a control board problem ?
Thank you very much
Marco
