I recently had a Euralloy Titanium 3KW 27inch immersion fitted to my new Gledhill Envirofoam Stainless Steel Hot Water Cylinder. Initially everything worked fine but then after about 3-4 days I found that the thermostat had locked out. Did a reset and it workd fine again for a few days then did the same thing again. After several lockouts I went back to the retailer and they provided me with a new stat (Backermatic) and a replacement 27 inch Titanium immersion (Thermotec Ltd) & stat (Backermatic). They suggested replacing the stat rather than the whole unit and see how things went.
Fitted it last Wednesday and again everything seemed OK but this morning the new stat has locked out and needed a reset. The temperature setting for the new stat is fixed, as there is a blob of white sealant/wax on the actual dial to stop any adjustment.
Spoke to retailer but they aren't able to offer any guidance as to what might be the cause, other than perhaps a power surge, and suggested I contact my plumber.
The immersion is run via Greenbrook 7 day digital timer to take advantage of Economy 7 electricty.
Anyone got any clues as to what might be happening?
I should mention my wife is aware of not covering the lid of the immersion with clothing etc.
