- Joined
- 27 Sep 2004
- Messages
- 1,301
- Reaction score
- 83
- Country
Just a quickie for you - if theres one immersion heater circuit supplying 2 seperate immersion heaters (in one tank) both are 3kW each, surely this needs to be turned into 2 seperate circuits one for each, as if both immersions were on at the same time they will pop out the 16A MCB.
Also how would you connect up a immersion heater time clock (economy 7 type from Newlec) which has a boost function. Currently the off peak supply controls the lower immersion heater, but the boost function wants to switch on the higher element.
Ah, just a thought, is 1 circuit for both ok, if the time clock doesnt allow both elements (ie off peak elemnt and boost element) to be on at the same time?? Thanks all...
