My immersion tank (its the type with the header tank on top of it and all covered in green insulation foam) keeps blowing or burning out its thermostats or elements every 4 or 5 weeks! it has a timer clock next to it on the wall, that regulates the economy 7 to just 4 hours a night for the main bottom element. however i have been going round and round with new thermostats not heating the water properly at first, then a visit by the plumber/electrician who re set the thermostat higher, then the thing runs fine for a few weeks, then suddenly either the water starts to get boiling hot, or we are woken up by the tank making a loud bang. also the amount of electric it uses goes right through the roof at the same time.
now i have had the wiring from the rcd fusebox to the control/timer box and on to the booster and main elements replaced, both daytime and economy 7 circuits. i have had the tank drained 4 or 5 times in the last 2 years, it flushed twice as we are in a hard water area, and have had 6 new elements for the main economy 7 element, and are averaging a new thermostat on the economy 7 main element, and sometimes the booster, every 4 or 5 weeks!
nothing my plumbers/electricians are doing seems to work, and i wonder if there is a fault with the timer unit - a horstmann economy 7 quartz- or a major earth fault with the system, power surges, or is it something to do with a fault inside the tank itself, thats causing the thermostats to start not cutting out properly and then not cutting out at all, then blowing?
it is becoming a nightmare, expensive and frustrating!
any one out there who can help?
cheers
cheers
