The door lock on our Indesit IWC6105(UK)E is on the way out so I ordered a new one which arrived today.
The problem is first I cannot see how to remove the old lock & secondly the new lock arrived with no plastic plugs to hold it in place.
I did talk to the company I ordered the lock from, as the old lock is held in place with two plastic pins, not screws & asked if the new lock came with everything needed to fit it, as ine of the old pins had pulled out & would not push back into place. Which part of the reason I need to replace the lock. It moved.
The new lock is a different design & I cannot see how it will attach as it has no pins & at least one of the old ones had failed.
Plus I cannot remove the old lock, it just will not manoeuvre out. Is there a way of doing it, or is it simply brute force??
