Indesit WIDL146 - Light 1, 2 and 4 flashing on drying cycle
10 Dec 2010
I have a problem with my Indesit WIDL146 Washer / Dryer.
When it goes to the drying cycle it stops and lights 1, 2 and 4 flash away. Washing works normally.
I found this thread http://www.diynot.com/forums/viewtopic.php?t=185931 which indicates that lights 1, 2 and 4 flashing means it's the dryer NTC / fan.
Could somebody please tell me if a) this can be replaced by me and if b) this is the right part - http://www.espares.co.uk/parts/washing-machines/indesit/widl146uk/p/1085/805/0/658969?page=2
Many many thanks in advance!
First of all check the thin wires that go to the ntc on the heater box are they broken. Next split the heater box is there loads of fluff on the fan blades. The check the condenser at the back is it blocked. When u take the heater box off u can remove the cold supply pipe and place in in the top of the condenser and give it a good flush though with water. I take it the heater and themo cut is working on the top does it get hot.
Many thanks for that rocks1. I will pull the machine out and go into the back of it.
The fluff you mention is always something that has worried me. With dryers in the past they have ALWAYS had a fluff filter that you can pull out and clean. There is nothing on this one and no mention of it in the manual - I've always wondered with this one - where does it go!?!?!?!?!
Down the condenser it goes you will see with the Heater box off
