indesit wil103
10 Mar 2010
Cleveland
Hi
Can any one help
My Indesit wil 103 washing machine fills then the easy iron and door lock flash as is empties.
Many thanks
no of flashes
1=short circuit triac
2=motor jammed check plugs
3=ntc open/short circuit
4=p/switch jammed on empty
5=p/switch jammed on full
6=prog selector managment error
7=heater relay stuck
8=heater relay cant be activated(common on new boards try tapping relays)
9=inompatable eprom
10=pswitch not sensing correctly
11=pump cant be activated
no 12
13=dryer fan does not work dryer ntc faulty
14=dryer ellement
15=dryer ellemnt not working dryer relay on pcb probable
no flashes but door lock led lit but fails 2 cstart check door lock motor heater and associated connections
were there is a lcd display all codes will be preceeded with an f except h20 =not filling
Hi Thanks very much
but both lights just keep flashing
the door lock very rapid
and the iron easy steady.
widl codes - light flashing from left to right are numbers 1-4
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
f1 and f17 share the same light
check motor brushes and make sure connections on pcb are tight.
