Induction hob wiring issue help
30 Sep 2014
Humberside
I have an issue with my induction hob, my kitchen fitters pulled the hob out whilst wired and overstretched it and pulled one wire loose.
I have attached photos.
I assume it goes on the free connector, the 3 free prongs.
But obviously cant just assume and stick on there, as there is a free prong on the live, neutral and earth, the hob wont power on its current state.
I have no instructions and cant seem to find the right ones on AEG website.
Id rather no call an electrician out (if I have to I will), when its only one wire needing clipping on.
If someone could point me in the right direction that would be greatly appreciated.
IF T2 is linked to T2 by a strap AND the Brown in the supply cable is fited to T1 then the loose Orange will ( 99% certain ) have come away from the tab on T1
The Orange supplies half the hob and the white supplies the other half
Thanks for your reply,
Not 100% sure what you mean by 'IF T2 is linked to T2 by a strap'
Did you mean if T1 is linked to T2 by a strap?
It seems to make sense that something would be wired to T1 as why bother having it there otherwise
