installing a new radiator
29 Mar 2006
Tyne and Wear
am installing a new radiator and wanted to know if i can come off the flow and return pipes from the neasrest radiator or do i have to take it from the manifold ?
Is the system on microbore (as you mention manifold)? If so it will be best to go back to it, if it's normal small bore (22 & 15mm) should be ok teeing flow and returns.
Not if the pipe size is less than 15mm. It will have to go back to the manifold.
so, in brief. am ok to tee into the 15mm but not smaller!!!
if its smaller i will have to go back to the manifold. so how do i find the maniflod, byjust lifting the floor boards and following the pipe work ??
how many outlets does the normal maniflod have ? ( 4, 6 ,8 )
