Hi All,
Just installed a new shower bath and we decided to go for a bath mixer tap that has a shower connected.
All went well with installing it, but the mixer does not mix the water - the only way I can get hot water out of it is to switch the cold off completley and have the hot on full - which gives me scalding hot water and not at a great pressure. As soon as I turn the cold tap - it completley takes over and i'm left with icy cold water - even though the hot tap is fully open.
From what I can gather, the cold is clearly at a higher pressure so its totally taking over from the hot - and pusing the hot back down the pipe! As when I switch the cold off again, it can take 30 seconds or so for the hot to pick up temperature again.
What baffles me however is that I have a mixer shower coming off the same pipework in the en suite - and thats always got lovely warm water at a great temperature and all I have to do is move the mixer valve slightly into the hot to achieve this.
So what's going on and what are my options?
I thought it was the tap so I took that back and got a different one, which was suitable for low pressure systems. It barely made any difference, if any.
Is it because the mixer shower I have in the en suite has a thermostatic control so it controls the flow ?
So if I installed a seperate mixer shower in the wall over the bath it would solve the problem?
Or will I be wasting my money and should instead go for a shower pump? If so, how does this work with my existing pipe work? Can I just install it in the airing cupboard to boost the pressure of the hot water or do they not work like that? The pressure of the cold is fantastic!
Sorry to ask so many questions just I can't get my head around what the problem is and the best way to solve it. I'm clutching at straws and every person I ask or website I visit seems to say something different. Plus the Mrs is on my back as she wants me to start tiling and I don't want to that till i'm sure the plumbing is all sorted in case I have to hide pipes in walls!
