- Joined
- 15 Oct 2004
- Messages
- 18
- Reaction score
- 0
- Country
A few questions on the best way to install a thermostatic mixer shower....
The shower will be above the bath and fed from a 50 gallon storage tank in the loft. The customer does not want the expense of a pump at this stage but would like to keep this option open for the future.
1. I assume the correct place for the pump (if fitted at a later date) would be in the airing cupboard?
2. If so, the hot and cold feeds would have to be run the long way. eg. from tank to other side of loft, down to airing cupboard, under floor in bedroom to pick up in bathroom? would this be the best option as I have to tee into the hot cylinder anyway?
3. Surrey flange, Essex flange or just an ordinary tee into the cylinder?
4. I will be installing the pipework in the bathroom behind a panel (not buried in wall) as bath is in alcove. I heard 'Aqua' panel from Wickes is the best option as plywood will swell up when wet. Any other ideas on materials or is this best option?
5. I presume the pipes going into the mixer valves would be 15mm diameter. Is it correct procedure to reduce down from 22mm into 15mm just before connection to keep an optimum flow rate?
Many thanks for your help
Laurence.
Laurence.
