installing zone valves
9 Aug 2009
Blackpool
Hey I seem to rember someone telling me there was a certain way round in which a zone valve can't be postioned. Can any one shed some light on this. Thanks for any help.
AB is the feed
B = Bath flow to cylinder.
A = heating flow.
its got an arrow on the brass body direction of flow.
or
the paddle will open the same way as flow direction not against flow.
Ok was just the two port vales I fort I heard someone say there was a way you couldn't put them. Think your reffering to the 3port valves. Thanks for any help
ok thanks so just to clear up there two port valves usaly come with an arrow to show flow direction? Thanks
You mean you can't install them with the actuator upside down. :roll:
CAESAR32";p="1319599 said:
Ok was just the two port vales I fort I heard someone say there was a way you couldn't put them. Think your reffering to the 3port valves. Thanks for any help[/quote
you may have been advised you cannot put them with the valve above the motor (ie upside down) in case the water leaks into the electrics
