Hi everyone
I’m looking at fitting insulated plasterboard, we have empty cavity walls.
If you can help with the following questions that would be much appreciated;
Do I need to remove the old wallpaper and plaster before attaching? Plaster seems fine.
Id like to use mechanical fixings not leaving an air gap, do I need to be concerned about cold bridging where the fixings are used?
Do I need to notify building regs?
What’s the best way to seal all gaps to prevent any heat transfer?
Do I need foil backed insulated plasterboard?
Thanks.
Thanks.
