hi all following on from my sizing post has anyone got any advice on insulated plasterboard?
Basically it's to cover a timber frame which is already insulated (between studs). My understanding is a need to insulate across the studs and then PB to avoid ghosting. I will probably add a skim coat after that.
Main concern is cost as insulated boards 27mm (10mm insulation 12.5mm PB) are around £28 a board. I could use normal board with a separate 10mm insulation? Any problems likely with this aside from having to fix twice?
Thanks and Merry Christmas all.
