Insulating/Sealing UNDER floorboards
6 Oct 2008
Glasgow
I have recently moved out of my nice warm flat into a an older house which is a good bit colder!
Anyway, I was wondering what the best thing to do regarding heat loss and draughts coming up from under my floor is?
Basically my house has suspended floorboards which I can get underneath, under the floorboards is a load of old rubble etc, when the wind blows through the house it blows the smell of the rubble up any gaps in the floorboards and also makes it colder
Ive been going about fixing any major gaps from the top side, but wondered if I can do anything underneath?
I read on a previous post I found that you could suspend some insulation under my floorboards
Is that a good solution to my problem? any other suggestions before I put carpet etc down
but surely some under floor insulation would help too?
I should also explain that the previous owners put in some rather rubbish stairs, the job wasnt finished very well and they have draughts at some bits - so the under floor insulation would sort that out a lot as there is parts that I cant get too to cover
PS any reason for the newspaper? will the smells not work there way up at some point?
cheers
Newspaper to stop the dust and protect underlay. Makes it last a bit longer.
The way stairs are contructed means you could only have draughts at the bottom under where they are fixed, there should be no way a draught could travel up through the stairs.
If you do want to insulate it will be a big job as all the boards will have to come up and then you could batten the joists and fit Kingspan or simiar in between, would need to check on ventilation to the boards if you did this. If you were going to that trouble I would relay T&G chipboard - no draughts then!
im talking about insulating under the floorboards though, I can get under my floors and I have a decent amount of space to move about
I have a hatch that lets me get underneath, so I dont need to lift the floorboards
the draft doesnt come through the stairs, but due to the way they are put up and the floor underneath it I do get some air through it
