Following on from a previous post, I am now taking down the lath and plaster from the ceiling in an attic room. Above it is a space about 7inches high, and above that the flat roof. Three questions:
1 - when I insulate this space, I presume I should leave the normal 50mm gap between the top of the insulation and the roof. Since there is no natural ventilation through the flat roof (only via the sloping roof to the sides of the flat roof), do I need to leave a larger gap or do anything else?
2 - I was planning to use something like Kingspan K7 for the insulation. Is it easy to cut this so that it wedges itself in place between the roof timbers, or will I need battens to hold it up there before I put the plasterboard in place? Also, any other suggestions for insulation materials?
3 - Finally, I'd like to put in halogen downlights in this area of flat ceiling. Are there any tricks for how to put all of this together without getting my knickers in a twist! In my mind (
)it involves first running the cables to the right place, putting in the transformer etc, then putting up the insulation leaving gaps for the cables and for where the lights will be inserted through the plasterboard, and finally putting the plasterboard up and cutting holes in it for the lights (remembering where I originally wanted them!) Anything missed? Any shortcuts?
Cheers!
Cheers!
