Friends
My central heating boiler is playing up. It works some of the time but is intermittent. When it does not work it appears to try and start but then stop itself before the burners properly ignite. It waits a few seconds and then tries again. I can hear the click of a solenoid on and off with each try.
What I have noticed is that when it does not work the timing is not random but instead at what must be the busiest times of day for gas usage. Before and after these periods it will run correctly. This would also explain why it worked fine until it started getting cold outside - it would wouldn't it!
Is it possible that it is responding to mains gas pressure? Does this happen or is it even possible? If that is the case is it almost certainly a faulty sensor in the boiler I would assume or could I actually have a mains pressure issue?
The boiler and house are about 11 years old. The Boiler is a Potterton Suprima and I think it is a 70L. It has had the main circuit board replaced.
Thanks for your help.
