Intermittent fault on house
A new boiler was fitted and ever after the house electrics RCD (Residual Circuit Device) goes off at random. I have tried isolating every circuit using the MCB's (Miniature Circuit Breakers) but nothing immediately showed-up (*but see later), I also switched off individual appliances on each circuit but no conclusive results. I had no electrical problems before the new boiler was fitted.
The CU (Consumer Unit) is a MK 5780s with a single RCD and 10 MCB's - the lighting circuits have C Type MCB's fitted about 7 years ago because light bulbs going kept putting out the RCD.
Before switching the RCD back on, all the MCB's were put to, 'off' and then each MCB switched on in turn with 10 seconds between each MCB going on to see if a fault was on that circuit.
*Occasionally, when switching the garage MCD 'on' the RCD immediately tripped, 'off', but this was not consistent, perhaps 1 in 3\4 times.
Questions:
- would replacing our CU with a twin RCD unit and having the MCB to the boiler and the MCB to the garage on the separate MCD's be a cure or only a 'patch' that does not find the fault?
- would fitting RCBos (Residual Circuit Breakers, overload) in place of the MCB's isolate where the fault is?
- if RCBos can be fitted into the existing CU are they, plug out, plug in? and is a reasonably competent DIY person allowed to do this?
- what kind of RCBos?, I have heard of 'single' and 'two module' types and 'short and tall'.
If what needs to be done is other than, 'plug and play' then I will use an electrician.
Any help much appreciated.
Questions:
