So 2 lights (stair and landing) controlled by two switches -one at top of stairs and one at bottom either switch should (I think) turn both lights on.
Top switch is a one gang , bottom one is a three gang (also controls hall light and outside light)
Recently noticed that sometimes the stair light doesn't come on...landing light always does
Have been trying to work out if it depends on the order it has been switched on/off/ which switch has been used but can't seemed to find a pattern... maybe it has always been like this ...
Stair light will originally have been high up and has been lowered by previous owner (Mr Bodge it - experience has taught me to call him) Did noticed this light not working years ago but I think it just kept blowing (enclosed fitting, pre low energy bulbs and maybe should have had a smaller wattage) - I put a temporary fitting on and then this new one following the wiring as it was about 8 years ago and have only just noticed the problem ...
Just looked at switches/fitting etc to check for loose wires etc ...this is what I have - they all have earths plus
http://media.diynot.com/39000_38899_55357_77342024_thumb.jpg
One gang switch has a red wire into top part of switch and a blue and a yellow going into bottom
http://media.diynot.com/39000_38899_55355_39897154_thumb.jpg
Three gang switch (on this gang) has a red going into top and blue and yellow into bottom
http://media.diynot.com/39000_38899_55356_86178179_thumb.jpg http://media.diynot.com/39000_38899_55358_50913964_thumb.jpg
Light fitting has a red to live, blue to neutral and a yellow wire cut off inside the cable
(Landing light has standard black and red feeds)
Have taken photos as well and will post them but struggling to get a good one of the light fitting - have looked at diagrams but getting myself in a muddle
So
Does this seem right?
Could it just be a faulty switch? (They are original 1960s)
No signs of sparking etc on any of the wires or any loose...
So
